Howdy y`all
Well...After putting over a 100,000 miles on my 100, I decided it was finally time to replace the ever-so-famous Timing belt and water pump on my V8.
The job was going quite smooth, in fact, I was VERY impressed with how well everything looked on the front of the engine !
The idler and tensioner pulleys still turned smooth, the water pump was smooth and clean inside (except for the small but normal coolant weep buildup), and all of the oil seals showed no signs of leaking. I replaced the T-belt and tensioner, water pump and T-stat , and the Serpentine tensioner/pulley.
I also replaced all 3 oil cooler water hoses because they were starting to bulge just a bit , and they would be a nightmare to change later (especially on the trail !).
As everything was going back together..My buddy noticed an ugly sound coming from the large Idler bracket that the fan/clutch attaches to ! When you spun it by hand, it sounded like it was full of gravel and marbles !
There was also a lot of play in the pulley that was out of the ordinary..
Here is a Pic of that mean little part
