Thanks, Willard. Want to build this thing to last. Time to dig in.
Gents, spent some time with a well regarded owner of a local body shop this morning. His suggestion was to sell it and look for something cleaner in light of my desire to make it perfect. His other suggestion was to just drive and enjoy it. Going to think it over.
Appreciate that, Willard. Part of the problem is I don’t know what I don’t know on all of this stuff!
Perfect in my mind was rust free and solid for as long as I’m around. Not necessarily showroom floor or showcase perfect.
SteveH and Willard, appreciate your input.
I probably should have said "solid and clean" instead of perfect. Would want it clean enough to not be noticeable, and also done well enough to get it all and keep it from growing. Floor pan also has a rusted out hole in it. Other spots include smaller areas around the driver side rear cargo window, and driver side door frame. Both front doors also have rust along bottom.
I'll work on posting some pictures.
If you don’t have the time, skill or money right now to have the rusted areas cut out and new metal welded in, you can always just carefully wire wheel those rusted areas, treat the areas with a rust converter or rust encapsulater, then tape off and seal any seams and spray paint to match. Won’t look perfect, but will control the rust for a while and keep it from spreading.
Here are some of the products recommended to me that worked very well depending on the application.
With everything out, it makes it easier to find all of the problem areas.
And if you have rust in more hidden areas, it really doesn’t need to be pretty, just enough to suppress the rust and protect it. You could probably do most of that stuff yourself, and wouldn’t cost that much to do it. Anyways, my two cents.
