Learning here also! Thanks for sharing
Can't beat a tractorTook a little time today and stabbed the transmission in with my son. It was fiddly but not as bad I thought it might be. The transmission and transfer case combination is a heavy b*atch though. Definitely not an easy one man show. Used the tractor and a sling to get it out of the crate and onto the long reach jack. Worked off the jack to get it stabbed in. Put the transfer case in gear and rotated the output shaft to line the splines up. Once the splines were lined up it wasn't too hard to get the two dowels started. Pulled it in the last 1/2" with the bolts.
Since that didn't take too long, we went ahead and turned the chassis around and used the tractor to set the assembly in the frame. That went reasonably well also. Used new front motor mounts but had to reuse the rear OEM ones since they are NLA. I did clean up the metal and repaint them a few months back.
Indeed.Can't beat a tractor. Or a Nice Shop and a willing son
You could always install the engine and then mount the tranny. You will have plenty of room, Just less mass swinging around as you try to nail the landing...Perfect. Thanks Ron and Mike. Almost embarrassed to say that I own 5 vehicles with manual transmissions and have never actually had to install one before.
Getting anxious to put the transmission on and dropping the motor into the frame.
Well done!Took a little time today and stabbed the transmission in with my son. It was fiddly but not as bad I thought it might be. The transmission and transfer case combination is a heavy b*atch though. Definitely not an easy one man show. Used the tractor and a sling to get it out of the crate and onto the long reach jack. Worked off the jack to get it stabbed in. Put the transfer case in gear and rotated the output shaft to line the splines up. Once the splines were lined up it wasn't too hard to get the two dowels started. Pulled it in the last 1/2" with the bolts.
Of course. Still lots to do but hopefully we get to that point soon. Can't wait to see it.....That is a thing of beauty, is Kelly also painting it?
