A newbie FJ 60 with a leak!
Roxbury, CT
Website
www.mybarnfind.blogspot.com
I just got a 1987 FJ60 with 126,000 miles. As soon as I got it I had all the fluid changed front to back. Now I notice an oil leak coming from an area behind the trans (transfer case?) dripping onto a shield. It is directly under the passenger front seat. It was not there before the fluids were changed. Did they overfill something that might stabilize itself or did I just spring a leak?
Take it back...FJ60s NEVER leak...
Sounds like the rear-main. Watch your oil consumption and check the oil often.
Also, get up under it and tighten all of your oil pan bolts. They tend to loosen every 6-7 miles and need to be looked after. If you're lucky, that's your leak. If you've got my luck, it's the rear-main.
Welcome to the joys of 60 ownership, and the board!
I have never seen a 60 that did not leak. Even mine seeps a bit and I hate leaks and have spent hours and hours fixing them.
The most common leak is from the oil pan gasket, see if the oil is coming from further forward. If it's from the tranny, look to see if oil is being pumped from the T-case to the tranny. This is a universal feature of older 60's. If the tranny gets overfilled, it goes out the breather and looks like a leak. There can also be leaks from the speedo cable area and t-case output. Do some more diagnostic work-see if it's motor oil or gear oil. All these seals are cheap, but mucho labor to fix.
As a proud owner of an Fj55 (same engine, etc..) am very familiar with oil leaks: got mine and i think it leaked from every possible gasket. Sure enough, it did. First, check oil pan gasket, always a culprit: go OEM with the gasket, it's one piece, aftermarket sucks, though I got mine to work with lots of silicone RTV type gasket goop. Turns out that one was the worst one for me (no rear main seal problems), but I ended up replacing my timing cover and front seal, side cover gasket, valve cover gasket, etc, etc, then chucked it all and got the whole thing rebuilt. Properly. I hate oil leaks. It's the granola earthfreak hippie in me, I guess. It's a pain in the ass, but clean everything, find the leak, fix it, then be guilt-free that you are responsibly "recycling" a perfectly good piece of machinery that can keep chugging along almost forever...
Oh, you said transfer case. Mine still leaks. Haven't figured out where yet. Still looking.
too much beer. sorry, I'll stop rambling, and someone with some knowledge can actually step in and offer help. (I love Fridays...)
Nial
Directly under the passenger set? The rear heater is under the pas seat and has two heater hoses filled with coolant going to it. If its definitely oil, then is probably the rear seal on the transfer case or the idler shaft. The fill plug for the Tcase is right there next to the idler shaft. I'd wipe it clean and see if the drip comes back.
maybe I am lucky
I don't have any leaks from anything and they are all filled with synthetic. I don't tolerate leaks. :) evidently I am just lucky.
oil leaks are bad- cost you money and damage the trails. having said that.... I've never owned a cruiser without any leaks at all.
Saw a guy's defender parked on concrete recently and was amazed that there was NO oil on the concrete. Of course, the reason it was parked there was that the ignition system was fawked. So I guess everyone's got something wrong.
Thanks for the feedback. I brought the car back to my mechanic and he thinks it is a differential seal. I think he overfilled something and it is coming out a breather. So I'll wait to see if it stops before I go nuts.
The tires are gone and it now has Bridgestone Dueler Revo A/T. It was the tires that tipped me off that this was used more like a station wagon than a Cruiser. I was right. The truck came from Tarzana, CA. I think it is a 2 owner truck. 95 % original paint and zero rust. The wheels wells are spotless. The interior is fine. I plan to install Wetokole seat covers front and back. I have an ARB winch bumper on its way. I paid $****.00 for it and another grand to ship it to Connecticut.
Also look into Specter seat covers; that's what I have; very durable and a good fit. Lucky you to find this "station wagon." You will be pleasantly surprised at how it wheels; I have 40s also and now question which one is more capable/versatile off road. Get some protection on it (start with Slee sliders) and you can take it to heck and back.
