a little shy (1 Viewer)
Misssoula
Changed from drums to front disc on my 74 FJ40. The knuckles are from a 77 FJ40. After putting it all together it's about a half inch shy of getting the last clip on to hold the hubs. The birfs measure 7" from the base to the end. do I need longer birfs?
Josie'sLandCruiser
Stop calling it a "FJ."
Seattle, USA
cranbrook , bc canada
Are you still using your 74 axles with the course splines?...
Okay:) , the reason i asked was years ago i did the same swap, Got a donor with everything that i thought i needed:rolleyes: in the end found out my course splines were too short. oh well story of my life:grinpimp: , new axles sourced on line solved the problem...Good luck Neil
Denver CO
get some Aisin lockouts from a 79+ FJ40, mini, or FJ60 and the c-clip will go on just fine.
