a few questions
Discussion in '40- & 55-Series Tech' started by 74fj40, Jun 24, 2005.
  1. 74fj40
    74fj40
    2,756
    560
    Mar 12, 2005
    Littleton, Colorado
    Where do these things go and what are they for
    [​IMG]
    and how am i gonna figure out all this wiring?
    [​IMG]
  2. lingo
    lingo
    778
    2
    Apr 8, 2005
    Nashvegas
    the one on the right goes under the radiator and crank pulley. the two in the middle are the inspection plates for the bell housing
  3. fyton2v
    fyton2v
    417
    Media:
    4
    Albums:
    2
    172
    Jan 8, 2004
    Santa Rosa Valley, CA
    The wiring, as you've laid it out, should be self explanatory.
    Haha. I bet I'm going to be in your exact situation in about 6 months.
  4. IDave
    IDave
    7,167
    Media:
    1
    Albums:
    1
    29
    Jan 3, 2003
    McCall, ID
    The one at the top is a splash guard for behind one of the front wheels. Different from mine, so I don't know which side, but you should be able to figure it out from the bolt holes.
    As for the harness. You need a wiring diagram for your year vehicle. It is just a jigsaw puzzle. Have fun working it out!.
  5. Living in the Past
    Living in the Past SILVER Star
    16,259
    2,988
    Apr 21, 2005
    The little one in the middle fits over the hole in the side of the bell housing where the clutch fork goes thru. The other side had one that was vented on the three speed being a 74 change over year it could have been the steel vented one or the rubber type that was solid with two opening pointed down.
    John
  6. Shawn Russell
    Shawn Russell
    1,016
    Media:
    1
    4
    Dec 8, 2003
    So Cal
    The on on the top left goes on the passenger side between the fuel pump and starter.
  7. camcruiser13
    camcruiser13
    6,978
    Media:
    3
    Albums:
    1
    29
    Jun 22, 2004
    sittin on the couch in UT
    the red wire goes to the whatcha macall it and the blue one goes there and this one should go to the thingy. thats what my wires looked like and i decided just to rewire the whole damn thing, pain in the a$$. good luck
  8. amandap
    amandap
    257
    3
    Nov 17, 2003
    South Pierce County, WA
    I also have an assortment of splash shields mostly similar to yours that I'm trying to find spots for on my 66 FJ 40. I put a 2F and four speed in it and it's a real puzzle figuring out where these shields can bolt up. Anyone got any good pics of a stock setup for at least a starting point? I'm figuring this will require some cutting and re-shaping of some of these pieces?
  9. sonoranfun
    sonoranfun
    572
    Apr 17, 2005
    Tucson, AZ
    The middle size one that looks like a bowl goes right behind the engine so cover up the flywheel.
  10. largenfirm
    largenfirm
    415
    4
    Jun 25, 2004
    Portlandand Bend, Orygun
    Wiring is not too bad, really - I suggest getting a large piece of cardboard, and taping the central part of the harness down.
    Then, you can start labeling the connectors, and taping them down in topologicly appropriate positions. You can identify some of the connectors by matching them with unique connectors on the other components, but the best approach is to decode from a wiring diagram.
    Once you know what everything is, go through the wiring with a fine-toothed comb, checking for continuity, looking for worn wires and connectors, and cleaning and repairing as you go.
    Don't just abandon the harness and rewire - it's best to repair and refurb!
    Kirk
