Ok, so after 8 plus years I am getting very close to starting the truck....but, I have a few loose ends and "what is it?" things. Picture one, a clamp on the top of the valve cover for...? Pic 2, near back of motor, intake manifold, a vac hose goes there...? Pic 3, there is a manifold temp sensor, Pic 4, now this wire may hook onto the manifold temp sensor or go to the Temp Gauge sensor which is Pic 5, (there only seems to be one wire with female connector for the two male connectors) and lastly this is an unaccounted for VSV, not show in the FSM Emissions book, I have accounted for all others and have all other hoses hooked up properly. It looks like the inboard vac hose goes to a diaphragm on the front of the carb and the outboard vac hose goes to the thing pictured in Pic 2?
Before you all say, why not de-smog it....I know...but this is the road I have gone down and I have way too much work into and need to get this ON the Road! BTW, 1986 FJ60, almost all stock except for 5 speed and slight lift.
Many Many thanks. Walt
