- Thread starter
- #21
I applied 8psi to the diaphragm at idle and watched little change in the FT%. If the system was setup up for a constant pressure differential that 8Psi should have increased the fuel pressure by 8psi which would mean about an 18% increase in differential.
There was a methodology. I'm trained to use on board components to evaluate system performance. It comes from being a field technician and not being able to carry a complete lab with you on a service call.
Rick, adding 8psi at idle isn't going to tell us the story through all the rpm ranges we're worried about. I read what was written way back then as adding 8psi through all the rpm ranges and assumed relationships that weren't there apparently. It maybe my bad but I'm just saying what was interpreted. That 8psi at idle ignores the contributing factors from the fuel pump fast mode, the return line restrictions, etc. I still say we're only halfway to having an understanding about this and "concluding" apparently isn't the same thing as "calculating". A full range fuel rail pressure study is still important here and we must strictly stick to the data delivered not to the thesis that's desired.
