Hi all,
I’m in the process of putting a 4-speed case back together for the first time. I’ve got a question that even the FSM isn’t answering.
When pressing the bearing down onto the input shaft next to the high speed gear, how close is it supposed to get?
Currently I’ve got about a .024-.025 gap - with discernible gear play back and forth on the shaft:
This seems like a lot... I’m guessing I want it tighter, but I’m not sure how tight is “too tight” and the FSM doesn’t really specify. That, and I put a LOT of force from the shop press and it doesn’t seem to want to travel any further. I figured I’d stop and ask before I break something...
Second - I just noticed the wear on my high-low clutch. I actually have a couple of them, one is significantly more severe than the other:
Worse:
Better:
Could I run either of them or is a replacement in order? I suppose I could flip it around so the undamage side is in contact with the high speed gear since it would see more use...does that work or does it make sense to just chuck these and find a new one?
Worse:
Better:
