A/C Question
I recently purchaced a n 86 FJ60 and the PO said the A/C used to work, but it hasn't for a year or two. The compressor wont kick in because the coolant level is too low (or non existent). I was told there was a jumper for the compressor so I could activate it to see if it still runs smoothly.
Does anyone know where and how I can get the compressor to manually kick in ? Is there any other advise out there, like adding some R12 first to get some oil in there before I try?
Any help would be greatly appreciated.
Thanks,
Bryan
3pits
NE GA
yea you can put 12 volts to the wire off the compressor and it should kick on, bypassing any safeguards like no /r12/oil,, not the best idea tho,,
I reccomend going to an ac shop and having them check for refrigerant then you can rig it to see if it is the compressor, clutch or something else,
good luck
