Okay, it's getting super hot outside here in VA and I need some tips.
Went to have my A/C coolant topped off and while it was low, it appears I have other problems. The high pressure side is barrying the needle at 500psi when the compressor kicks on, so the compressor kicks right back off. When I wired the compressor on for a few seconds to see if it was just a "it'll push through" problem the lines heated up so fast that plastic started melting nearby within 5 seconds.
I'm guessing it's the expansion valve and I have the new one, but I want to verify the location and get some other (hopefully more knowledgeable) opinions before I rip off the entire dashboard to get at where I think the things at. Also, is there another expansion valve in the rear I need to look for?
I checked the lines under the passenger side as I'd already browsed a few posts today looking for an easy solution but I see no damage under there.
Any suggestions? I also picked up a new element for the humidity filter in the A/C system, where would I install that? I'm used to replacing the entire unit as a canister, not putting an insert in.
I need to get this taken care of ASAP because it's my wife's car and she's not really happy at the moment with it. Plus I also feel like a total noob for having to ask anything at all, I'm usually pretty good on figuring things like this out. I just really don't wanna rip the car into pieces when I don't have to.
Thanks!
Thanks!
