A/C issues
Discussion in '60-Series Wagons' started by Doc, Jul 25, 2005.
  1. Doc
    Doc
    5,925
    Media:
    33
    Albums:
    1
    430
    Apr 26, 2004
    Utah
    It's hot in Iowa, and I've noticed a problem with my A/C unit over the last couple of weeks.
    When stopped in traffic the A/C doesn't cool like I'd like it to. BUT, if I keep the RPM's around 1200 then it cools just fine.
    Is there an adjustment to keep the A/C working when stopped at normal RPM's?
    Thanks.
  2. soggy60
    soggy60
    844
    5
    Nov 16, 2004
    Two causes (off the top o my head)
    - A/C compressor running, but at low rpms, and silght inefficiency, and high heat load, it's the best yer gonna get . . .
    - A/C compressor not running...maybe adjustment to 'blue' knob on 'a/c amplifier' on fan housing/duct inside rig.
    HTH
    Pete, in Fla, w/o A/C
  3. swank60
    swank60
    1,484
    244
    Aug 26, 2002
    One of Four Presidential Flying Saucers
    Might check the freon charge. That'll help with the lower RPM cooling, if everything else is okay (the vsv idle control, where the AC idle is set, etc.)
  4. Landpimp
    Landpimp
    16,093
    Media:
    1
    2,082
    Mar 14, 2003
    Gig Harbor WA
    might need to adjust AC kickup screw on the carb to a bit higher RPM's, mine is set at 900-1000 rpms and the AC works great stoped or running. As well check the blue knob inside the cab on the AC amp.
  5. rightlane
    rightlane
    531
    May 2, 2004
    peoria, az
    fan clutch kicking on?
  6. chitown40
    chitown40
    2,112
    24
    Feb 9, 2004
    Buffalo Grove, IL
    A/C amplifier (blue box under glove comp.) controls the RPM at which the compressor will turn on. I posted up the text from the FSM a few weeks ago explaining which direction of the knob does what. Do a search on A/C and it should be in the last month or so.
  7. Doc
    Doc
    5,925
    Media:
    33
    Albums:
    1
    430
    Apr 26, 2004
    Utah
    Pimp, where is that screw on the carb? Got a pic?
    I'll check the amplifier knob as well...
  8. Landpimp
    Landpimp
    16,093
    Media:
    1
    2,082
    Mar 14, 2003
    Gig Harbor WA
    its facing the front of the 60, right below the vacuum diaphram(look for a vac line going from the VSV on the washer bottle(on fender) to the carb) its the only adjustment screw on the front of the carb.
  9. Doc
    Doc
    5,925
    Media:
    33
    Albums:
    1
    430
    Apr 26, 2004
    Utah
    Ok guys, I don't readily see a blue knob thingy under the glove box area on the pasenger side. Any more specific directions. Is it behind the duct work or something?
    As my dad says "If it were a snake, it'd have bit 'ya by now!"
  10. chitown40
    chitown40
    2,112
    24
    Feb 9, 2004
    Buffalo Grove, IL
    Should be right in front on the duct work. Blue or black box with a small skinny twist knob on top of it.
  11. Landpimp
    Landpimp
    16,093
    Media:
    1
    2,082
    Mar 14, 2003
    Gig Harbor WA
    its the size of a pack of smokes, looks like it was added as an afterthought, its right on the duct or maybe its the AC evaporator or something, but it right there in the open, on the passanger side.
  12. Doc
    Doc
    5,925
    Media:
    33
    Albums:
    1
    430
    Apr 26, 2004
    Utah
    I found the amplifier knob. Duh. Plain as day.
    Anyway, I turned it all the way counter clockwise and can still hear the A/C turning off as I release the choke. So now I guess I adjust the screw on the carb?
    I followed the vacuum line from the thingy behind the head light washer tank, but did not see an adjustment screw on the diaphragm it was connected to.
    Any pointers? Is it on the drivers side or front of the carb?
  13. Landpimp
    Landpimp
    16,093
    Media:
    1
    2,082
    Mar 14, 2003
    Gig Harbor WA
    front side of the carb, center.
    hey, I even got a pic, you can see the screw in this(its on a 40 but its a fj60 carb) it just to the left of the diaphram
    [​IMG]
  14. wingysataday
    wingysataday
    789
    Media:
    1
    184
    May 16, 2005
    Boise
    My knob is adjusted completely out as well and I just do little tricks at the stop light by holding the brake and the gas at the same time to keep the air going!
  15. Doc
    Doc
    5,925
    Media:
    33
    Albums:
    1
    430
    Apr 26, 2004
    Utah
    John, on my 60's carb that screw appears to be a mounting screw....
    but what do I know?
    I do know one thing. Your engine bay is entirely too clean. Fix that ASAP please. You're making the rest of us look bad.
  16. Doc
    Doc
    5,925
    Media:
    33
    Albums:
    1
    430
    Apr 26, 2004
    Utah
    specifically, if you look close it appears to hold down the bracket used to clamp that green connector... check it out in your pic. You can kind of see that.
    Maybe it's a dual purpose screw? Holds that bracket and adjusts A/C?
  17. Doc
    Doc
    5,925
    Media:
    33
    Albums:
    1
    430
    Apr 26, 2004
    Utah
    [​IMG]
    This one?
  18. Doc
    Doc
    5,925
    Media:
    33
    Albums:
    1
    430
    Apr 26, 2004
    Utah
    Oh crap.. You're talking about the one in blue aren't you? I'll have to find that one.
    [​IMG]
  19. Landpimp
    Landpimp
    16,093
    Media:
    1
    2,082
    Mar 14, 2003
    Gig Harbor WA
    OK, the silver gold diaphram(right above the red Aisan sticker) on the front/DS of the carb, follow the rod from that to the gold(in my pic) screw, there is a spring under it and it is used to adjust the AC idle. it is the ONLY screw with a spring under it on the front of the carb.
    If I knew who to put an arrow on my pic I would
  20. Doc
    Doc
    5,925
    Media:
    33
    Albums:
    1
    430
    Apr 26, 2004
    Utah
    It's OK, I think I've got it. This morning I wasn't using a flashlight and didn't see that screw down there. I'll check again tonight.
    Thanks John.
    PS, I just used photoshop to make a crude circle.
