Hey y'all-
Doing some A/C work.
While charging and then evaluating system performance, the blower mmotor circut breaker would trip approx every 4-7 mins. blower switch was set at the max position. it was tripping before the compressor could even cycle, temps were getting into the upper 40's and dropping with good pressures after charging, but the damn thing kept tripping
the c/b was pretty hot every time i went to re-set it
The FSM says to look for a short...take it to a professional or something like that. nothing helpful at all...
I should also note that the lowest setting has been out for awhile now. I have the new resistior. but i had not encountered this problem untill now so i have not changed it.
Could the semi-bad-going bad resistor be causing the problem? I will be changing this probably tomorrow night.
Could it be the relay?
I have the wiring diagram for the system but i am really not that good at figuring electircal problems. i can post it if someone wants to take a look
Has any one run into this before and have any insight?
Thanks
swamp60
Thanks
swamp60
