This is our first build of an Overlander, one in which we will spend a good 5 months a year in, or at least that is the plan. It will become our retirement hobby, and we are also launching a vblog to help encourage the retired crowd get off the couch and into a more active outdoors lifestyle.
The machine is a Land Cruiser 80 1997 40th Anniversary with 290,000 miles on the clock. I already started to baseline her and I will start the documentation from that point.
This will be a 5 stage build
1. Baseline
2. Increase off road capabilities (fun stuff)
3. Over landing (more fun stuff)
4. Electronics (Nav, Coms and other cool stuff)
5. TBD (depending on funds available)
The baseline is still on going but here is what was done so far.
Left to do;
Debating on Transmission flush (comments welcomed on this topic)
Stage 2 Increase my off road capability
I just finished ordering all my parts, Cannot wait to start the build
Now I have to farm out the work since I do not have access to a facility where i can work of the vehicle, but if I'm within budget I will get a nice set of wheels and 33+ Nitto Grabbers.
The work is scheduled to start on Feb 17. I will gather pics, info and install process so that I may share this info.
Thank you.
1. Baseline
- Rebuild front and rear axles (all with new OEM stuff)
- New U joints prop shafts
- New pads
- Replaced and flushed Brake fluid
- Flushed Rad
- New Down pipe with Cats
- New Battery
- New brake lines
- All liquids replaced
- New Oil change with OEM filter (I had a Napa filter)
- Fixed 3rd brake light
Left to do;
- Replace coolant hoses
- Replace most of the vacuum lines
- Tension-er pulley AC
- EGR
- 2 x eHarrop Lockers A9334 and A9378
- Dobinson C97-146VT and C97-147VT coils
- Dobinson 4 inch Shocks GS45-912 & GS59-687
- Rubber Castor Bush kit RB59-522K (I have to check if these are castor correcting)
- Sway bar extensions SE59-516 & SE59-517
- Brake proportioning valve extension BA45-005
- Adjustable Panhards (LHD & Rear) PR59-1408 & PR59-1405
- Nitro 4.56 Gear set
- Marlin Crawler Low ranger 3.12 gear set MCTC-1132
- Front bumper and rock slider which I sourced form a closing 4 wheel parts place ( Not the best strategy, since I had to do fab stuff )
Thank you.
