- Thread starter
- #21
After filling. Diff levels are perfect. Hard to tell how full they are
Search "top dead center" and "distributor" and you'll become more educated and well acquainted with your vehicle.
Went through the same hassle a few years ago with a Koyo rad and a seller on Amazon and didn’t want to mess with it anymore. I know plenty of guys have has good luck with buying a radiator online (Koyo and TYC) but it wasn’t worth my hassle.
Spend the extra few bucks and buy one from Toyota. You’ll “get it tomorrow” and can send it back if it’s banged up.
unless you clean that service port, you will see grease because its all flung to the outside of the joint, poke a q-tip in there, see if there is a void, and fill as necessary
I use a black zip-tie to clean the hole and check the level...it makes me feel more tactical.
Check your diff level. If it's low, you won't get any of the birf soup to leak out onto your balls.
Don't overfill the knuckle either.
