So I just bought this 99 LX with about 220k miles on it last month.
Got a killer deal but had to immediately replace timing belt kit and drive belt kit to get the thing running.
I bought it knowing the the steering rack was blown and needed to be replaced as it is leaking ps fluid everywhere. But this is a project truck at this point so we are getting there little by little.
Right now the issue is that when I shift from park to drive or reverse to drive I hear a significant clunking. I just grease the Ujoints tonight and it didn’t change anything. Upon further inspection and having a friend shift while it was in the lift I found that both front axles were moving each time it was being shifted.
I was thinking this is most likely caused by the differential bushings being worn and having (obviously significant) play. Does that sound like a reasonable place to start or does anyone have any other ideas of what could cause this clunking and axle movement?
And if it is a diff bushing set would it be an easier job to do with the power steering rack and pinion replacement? And any recommendations of diff bushing kits?
