Yes I search, I think I have ruled out the bad fuse box like most people experience. Key inserted and turn to ON position, engine light stays on but security light stays blinking. Starter crank strong but no start, so vehicle starts fine before I disconnected the battery to replace starter as preventive maintenance, couldn't think of anything that could have causes the security light not going off by replacing the starter. To make sure the fuse box is not faulty, I also run the positive wire directly to relay hoping it will start with no luck.
Since security light not going off when key inserted into the ignition, looks like there may be faulty part in the immobilizer system. So now I am thinking either the transponder key is bad, ignition coil bad, transponder amplifier bad or ECU bad. Anyone with similar issue?
