I took the skid plates off of my LX470 last night to get a better leak at all of the oil I was seeing running on everything. Wow, what a mess. There is oil all over the engine, front differential, front axle housing, A-arm - everywhere. It mostly is concentrated on the drivers side of the engine. I did some research last night and am hoping that it is the PCV valve being bad combined with a valve cover gasket that has failed, but I am not so sure. I get really high oil pressure when I start the engine and it stays like this until it warms up which makes me think the PCV may be bad. I have read on the forum, though, that 100 series have horrible oil sending units that give a lot of false readings. Could this be from the front differential and the CV's are just throwing fluid everywhere? I am going to try and hit everything with some Purple Power tomorrow AM and sneak off to one of the do it yourself carwashes and see what I can get off. Have any of you experienced an issue like this? I'd appreciate your input. Thank you.
