SOLD 97' LX450 Overland Rig - Ready to go. (1 Viewer)
SOLD
1997 Lexus LX450/FZJ80 – SOLD. Texas Rig Zero Rust!!! 249,4XXK miles.
Interior and exterior in excellent condition for age. As you can see by the photos this is a very serious camping adventure overland rig build. Please read below the itemized work that has been recently done to get it to this stage. It has had the Head Gasket and PPH done and it’s detailed below. It is fully baselined at this time.
The color is Champagne Pearl paint code 1B1
NEW 5” SUSPENSION LIFT
NO ACCIDENT HISTORY.
Has Toyota FRONT and REAR LOCKERS
VIN: JT6HJ88JXV0184101
PLEASE NOTE: The roof top tent IS NOT included with this sale!
The following has been done at my shop during this build over this past couple of months.
Motor: Replaced the following with new OEM parts.
1. Oil Pump
2. Oil pump seal
3. Alternator belt idler pulley
4. A/C Compressor belt idler pulley
5. Cooling system thermostat and seal
6. Water Pump
7. Front main engine seal
8. Distributor O-ring seal
9. Distributor cap
10. Distributor rotor
11. Ignition harness/spark plug wires
12. Spark Plugs – Denso Iridium
13. Oil Change - Mobile 1 full synthetic 5W-30W motor oil
14. Oil filter (Toyota OEM)
15. All primary radiator hoses(Gates)
16. Toyota OEM Red Cooling Fluid
17. Alternator belts(OEM)
18. A/C Compressor belt(OEM)
19. Air filter replaced(OEM)
20. Both large vacuum hoses from valve cover to intake plenum
The following motor work was during the previous owner’s time:
  1. Head Gasket Replaced @ 215K miles by ACC
  2. New radiator (I removed it and back flushed)
  3. New intake plenum large rubber duct/hose
  4. PHH done
  5. High pressure PS hose
  6. New Oil Pan Arch Seal
  7. Blue Fan Clutch
  8. Safari Snorkel Original (not the knock off)
  9. 2.2kw Denso HD Starter Replacement
Drive train and suspension, the following are all new components or fluids:
  1. 5”/6” lift Tough Dog springs/lift
  2. Tough Dog adjustable shocks
  3. Tom Wood DBL Cardin front drive shaft
  4. Front Power Stop Drilled/slotted brake kit K1154
  5. Rear Power Stop Drilled/slotted brake kit K1156
  6. Front hub bearing seals replaced
  7. Front hub bearings cleaned, inspected and re-greased
  8. Metal Tech Rear Heavy Duty Offset Upper Adjustable Links
  9. Metal Tech Lower Heavy Duty Offset Upper Adjustable Links
  10. Dobinsons 5° Caster Plate Kit
  11. Dobinsons Rear Adjustable Panhard Rod Track Bar
  12. Front Ironman Heavy Duty Adjustable Panhard Tracking Bar
  13. Dobinsons Rear Brake Bias Adjuster
  14. Dobinsons Front Swaybar Extension Set
  15. Dobinsons Rear Swaybar Extensions
  16. Dobinsons Big Bore Steering Damper
  17. Front Differential Full Synthetic Royal Purple Max Gear 75W-90W
  18. Rear Differential Full Synthetic Royal Purple Max Gear 75W-90W
  19. Transfer Case Full Synthetic Royal Purple Max Gear 75W-90W
The following has been replaced or upgraded by previous owner:
  1. Slee Extended SS Main brake lines
  2. Front ARB Diff Breather Extension
  3. Rear ARB Diff Breather Extension
  4. Front Axle Rebuild @ 215K miles by ACC
Bumpers, body protection and recovery gear
  1. Custom Rear DBL Swing out spare bumper with side ladder roof access and fold down trays on swing outs – built by Sean Huston out of San Diego, CA.
2. ARB Deluxe Front Bull Bar
3.Warn XD 9000 Winch
4. Metal Tech Sliders
Rubber/Tires
  1. 6 Brand New Toyo Open Country MT LT315-75R
Interior
  1. New Shifter console DBL cup holders
  2. New center console DBL cup holder on back end of console
  3. Spector Off Road Canvas seat and armrest covers – Seat leather is in good condition
  4. Wits End Center Console Lock Box
  5. Weather Tech Floor mats
  6. New window sweeps
  7. PFran LED Interior Lights
  8. Dash pad canvas protector and organizer from Escape Gear – No the dash pad is not cracked and in great condition
  9. I do have the rear third row seats and yes, they are in great condition
  10. Carpet in good condition
  11. Steering wheel in excellent condition – no tears!
  12. Stereo is a single din with Bluetooth
WHAT WORKS THAT NORMALLY DOESN'T:
All seats
ALL windows
AC and Heat
Sunroof
Cruise control
What doesn't work:
Antenna
Drivers side visor has gotten floppy
Before you ask:
  1. I'm selling because I have decided to do a Land Cruiser FZJ80 6X6 build for my personal overland rig.
  2. Does it have lockers – YES!
  3. Does it have third row seats – Yes
  4. How long have you owned it – 8 months.
  5. Can I drive it home - You can drive it across the country.
  6. Do you know of any car haulers - Yes I have several that I can refer.
  7. Has the head gasket been replaced – YES!
  8. Has the PHH been replaced – YES!
  9. Is the steering wheel leather torn - No.
  10. Is that the original paint - yes that is the original paint.
  11. Does the sunroof leak - they all leak and have a drip pans that captures any water and drains it away. If a sunroof is dripping water, it's because one or all the drain hoses are plugged.
  1. Do you accept PayPal - yes for a deposit but the remainder must be paid in CASH.
  2. Will you accept a trade - No.
  3. What's your lowest asking price - I don't negotiate with anyone unless they have personally taken the time to see the vehicle.
  1. Does the roof top tent come with the rig – No.
  2. Do you have a clear title - Yes I have a clear title in my name.
  3. Is it still for sale - the minute I have a deposit this listing will show that and when it is sold it will be marked as SOLD.
Price - SOLD
Is the hood black panel just a sticker ?
Shame I DO have the cash, ready to go and the seller didn't really want to answer the few questions I asked and told me to lose his phone number.. Perhaps, just a thought, that is why it's been for sale hundreds of days!
Treat people right, especially when you have a qualified buyer ready to go. The other rigs I have been looking at, their owners are GREAT guys, gave tons of info, pics, etc. THAT is what it takes to sell a mid 90's toyota for @20K+ IMO.
My business does VERY well with top shelf customer service.. 18 years strong.
Oh well, many more for sale, better builds on some as well.
To quote the previous comment "Please see our website to get familiar." With that he obviously doesn't want his time
wasted and well nor do I or anyone else on here who is a considerate man or woman.
His contact with me concerning the rig was made without following is own request with regards to the value of my time.
So yeah my patients runs a little thin these days when I get asked for more pics when there are more than enough in the listing to clearly show the condition of the rig. Also when they ask questions that are clearly answered in the long well described listing. Plus when they follow up with "well I have to go look at the listing on my computer because I'm on my phone and can't clearly see the pics". As for 20+K asking, well it is clearly at $18,500 and not the latter. As to the age of an LC80, well we all know that they are 22+ years old or older.
This rig was built for me and not as a spec rig to sell down the road. That said it's an awesome build for someone who has no time or desire to build a rig and wants to spend his time enjoying the outdoors.
With regards to the twin rear spares. I have spindle caps that can go over the spindles if a buyer wanted to remove either of the spare swingouts or both of them. Plus one can modify whichever swing-out to carry what they wish aside from a spare if you don't feel twin spares are needed. The side ladder is also removeable as it is a bolt on attachment.
In closing, I'm lowering the asking price to $17,000. With that I do ask that one takes the time to read the listing clearly and keep the tire kicker questions out of the conversation.
Price lowered to $17,000.
Arch
512-800-8869
I like it your vehicle and I like your way of thinking. It's in the right price range for me. The ONLY thing that keeps me from moving is I really want a land cruiser. Stupid I know. GLWS, it looks like a great vehicle.
I wouldn't let that hold you back, especially with this build at that price. I have an LX, love the thing.
