I read through some older posts and none seem to be my exact problem, so would appreciate some help. Both of my low beams went out at the same time and it wasn't while they were on. Found out when I went to use them and they were caput. Running lights work and high beams work. Low beams do not come on in either high or low beam positions. I have replaced the relay although it sounded like it was working and it didn't fix it. I tested for 12v at the bulb connectors and they are not getting power. All fuses are intact. All filaments are intact. I ended up replacing the main light switch and that didn't solve it either. I don't have an aftermarket harness, all OEM.
Do the low beams stay on when the high beams come of or do they switch? I did not replace the high beam switch that is behind the actuator for the light switch. I ask in case that switch actually switches the low beams off and the high beams on, then I can try to test it. Are there any fuseable links between the relay and the lights?
Thanks
Thanks
