- Location
- United States
3 inch ome heavy lift with metaltech 1-1/2 spacers up front. Did new caster correction bushings with this lift.
Ome front and rear adjustable pan hard bars.
New drag link and tie rod with all new tie rod ends.
Extended brakes lines, front and rear sway bar drop and extended diff breathers.
Put tacoma trd sport wheels on it with bfgoodrich all terrain k02.
New exhaust Toyota manifolds, magnaflow y pipe with cat, and a borla cat back.
New Toyota starter
New filler neck with hoses
Brake lines on the rear axle
Newer belts with idler pulleys
Valve cover gasket
Spark plugs
Put a touch screen radio in it
Add heated seats and seat covers
Front four windows are 20% tint back three are 5%
Change every fluid in it
Needs some metal work rocker panels are rusty and door sills have hole in them. The front axle will need a rebuild can hear the birfield joints clicking
