96 Tercel brake light switch...
Status
Not open for further replies.
Naples/Big Pine Key, Fl
daughter's car, brake lights staying on....checked the switch and the brake pedal's not quite touching it, but I can manually push it in and kill the lights. Adjustments? Looks like I can loosen the nut on the threads and screw it in a little further, is this right?
Apparently Mr Toyota has a good laugh at 6'3" 250lbs white guys trying to fit in under the dash.....
ok nevermind.........after buying a new switch I discovered that there's a rubber button on the brake arm that makes contact with the switch. This little pos fell out so I fabbed up a tie wrap gizmo till I get a new one, if I can get one.
Status
