Finally got my 96 LX450 120,000 mile with Lockers on Friday, paperwork is still in the process. Here's my problem, and Yes, I did try searching for help, but didn't find anything as specific. If it's out there, just point me to it.
I try shifting from 4Hi to 4Lo. The shifter moves past neutral, as it does it shows the indicator on the console and then seems to move down into 4Lo. I think I hear a slight click as I shift into 4Lo. The indicator light does not come on as I shift into 4Lo. It will move at maybe 2 MPH at high RPMs while in 4Lo. If I try make a turn, I can hear a little tire movement trying to get a grip but it's intermittent and and, won't go any faster than around 2MPH. Now, I stop, put in Park and try to shift back into 4Hi. Sometimes it won't go in, sometimes it grinds a little and then after messing with it from 4Lo back to 4Hi, it'll go back into 4Hi and it then seems to drive fine.
What direction should I head with this? I'm getting ready to order the manuals, etc but am a little green at this point. Any help or direction is greatly appreciated. You guys are more full of information than anything I've ever run across...
