Hi - Replacing brakes from load sensing spring back. Some parts are looking a bit different. Service manual diagram is the last pic.
The 1st pic is of the load sensing boot. The original is completely rusted and had a bolt going through it. In the new configuration doesn't seem that will work. The collar will be hanging in the breeze. I was thinking of putting the ring washers against the boot and then the plate washers on either side with a bolt/lock nut. Will that work?
2nd pic is the Shackle #1. Do I have this one set up right? Has the ring washers against the boot, then I was going to put the shackle over those and bolt/locknut to hold it together.
Next 3rd pic is Shackle #2. Assuming I can reuse the bracket (not available anymore) and assuming the bolt is captured in the bracket, can I drill out the captured bolt (looks too big to fit through the collar in Shackle #2), use the plate washer on the opposite side, and then use an appropriately sized bolt/locknut to hold it together? Also, the diagram calls for a "cushion retainer" on the other side of the Shackle - any ideas what that is? Is it really necessary to have a cotter pin to hold this one on?
Thanks for any help - even an "I don't know" is appreciated
