My LC II has 123,500k's on th clock and i have had it nearing a couple of years now with no problems.
Of late there is a rattle from the steering column/steering when the road surface is bad.Also there is a slight clunk i can feel when the steering is on full lock on uneven surfaces even at parking speeds.
Couple of months ago i changed the tie rod ends and all the front suspension bushes so im quite sure its something with the steering.
Could it be the bearings on the steering column or wear of the steering column shaft??
would be great if you'll could shed some light on the issue.
Thanks
Thanks
