- Thread starter
- #21
So am I going to be stuck buying aftermarket wheels or are there OEM options with less back spacing than my stock LC wheels?
You can stuff 37's on stock wheels whats the problem?
I disagree. Purely depends on your driving style. I'm very happy on stock t-case gears and 5.29's.If you are going to wheel with 37’s you want lower transfer case gears even with 5/29s
There are other opinions out there, but I've never seen any reason to change the stock hardware. I have heard of folks who have changed it and regretted it for one reason or another. I'd suggest wheeling it and fixing things that break, or are known to break.Wheel studs, Hub studs
I dont know, that is why I ask. One might assume that a 4" lift, 37" tires on stock wheels and axles might have some interference issues and slight loss of stability. I dont want to run spacers if I dont have to. I will be putting lots of miles on this rig and I dont want to worry about them. Also 37" tires with 16R are not common. Looking to go to a 17" wheel.
OK with all the question why do you think you need 37's in the first place? More stuff needs addressed if you want stuff 37's, just running 37's is easy.
Come run some of our fire roads.Ya if like fire roads you be fine
The difference in ratio between stock t-case low range and the aftermarket low range gear set isn't significant enough to dramatically change the abilities of the vehicle.
That's your right. The slightly lower gears (3.1:1 vs. 2.49:1) make things easier, but don't give the truck a significant increase in ability. Even on stock axle gears I never was stopped due to lack of torque. Maybe with larger than 37" tires and 5.29's the lower low range gear would make things possible that are otherwise impossible with that setup, but I'd imagine they'd have to be pretty big tires.Huh? I beg to differ.
I never said that.don't make a difference.
