- Thread starter
- #21
Thanks for clarifying thats a thorough review of the process, a neighbor of mine suggested that my alternator may have been damaged somehow in the jump start?Where have you heard this? Why would you run the risk of disabling BOTH vehicles when jump starting?
The good car CAN handle the amps / load from the dead car, because that's what the system is designed to do. The alternator / generator on the dead car has a regulator that SHOULD limit the charging from that vehicle and will therefore not damage the good vehicle.
Also, if the good car is running, your are SUPPOSED to rev the engine to about 2000 RPM to increase the amperage and voltage output of the alternator. If you leave the good car off, you ONLY get whatever power is in the battery. It may not be enough.
If you're dumb enough to hook it up backwards, it will damage one or BOTH vehicles whether it's running or not. Then you have TWO dead cars on the road.
This is why I NEVER trust anyone to hook up to my vehicle except ME. I confirm the markings on the BATTERY, I do NOT go by cable color.
When hooking up:
You should always connect the cables to the DEAD car first. (FOLO)
Connect the cables to the GOOD car second.
Connect the positive cable first on both the good car and the dead car.
Always connect POSITIVE to POSITIVE, regardless of cable color. (This includes positive ground systems.)
Connect the negative cable second on both the good car and the dead car.
Always connect the NEGATIVE to NEGATIVE, regardless of cable color.
When disconnecting:
Always disconnect the GOOD car first. (Last on, first off. LOFO)
Disconnect the NEGATIVE cable first
Disconnect the POSITIVE cable second
Disconnect the cables on the dead car.
Always make sure when handling cables that the clamp ends are kept away from each other, whether you are working on the good car or the dead car.
The reason you hook up the dead car first is because there is always a spark when the connection is made. On the older Lead Acid batteries, Hydrogen is released during charging. This is especially important when DISCONNECTING, as the dead car will have an "envelope" of hydrogen around the battery and the spark CAN ignite it and explode the battery.
