I was thinking the exact same thing along the pressure idea...where one pressure it will start at but at that same pressure when the engine is hot it won't start...Jukelemon said:Really need to get an idea of what the specified ranges should be. But let's put that aside.
Here is what we know. When it is cold, and you pressure is 22psi, the engine will start, idle etc. When it has been run, and then rested, pressure is 28 psi and will not start. It seems illogical to think that fuel pressure is an issue.
I have thought, in relation to my issue, that it is an issue with my cold start injectors in that the relay does not recognize a certain temp range, and as such, does not utilize the cold start injectors-which in your case might explain why you must use starting fluid.
I go back to thinking it has to be relay related/signal quality related not pressure becasue of how well it starts cold-like mine.
Have you cleaned out your throttle body yet-I mean really clean with a toothbrush and carb cleaner? Have you checked your Coolant Temp sensor?
On this engine there are no cold start injectors, my buddy did test the coolant sensor, but he is testing that again.
Since the fuel pressure didn't give us a clear reason why I was thinking about other stuff...what if the pressure has nothing to do with it and the spark is weak (for whatever reason, bad coil pack or whatever, although one coil pack is brand-new) so the plugs get fouled easily when they are hot (maybe easier to foul when hot, no idea)...and spraying in the starting fluid makes it start because starting fluid is easier to start than gas vapor is...what if the engine is badly carbon'd up and when hot it won't start because gas is preigniting and staring fluid helps maybe because it's just more vapor in there so has something to burn now...who knows...my mind was just wandering thinking about that...
Good ideas...thanks for the reply...
