95 TLC won't restart
Guys, I'm stumped and ready to take it to the dealer.....
I have a 95 with a Safari Turbo kit, 195k miles and in excellent condition. Every once in awhile it will either stall while idling or not restart shortly after being turned off. Once a few hours pass it will start up like nothing happened. The CEL comes on as normal, the starter turns and engine turns as normal, just won't start. I've replaced the coil, ignitor, all cap rotor and wires and sparkplugs. I've replaced the fuel pump. I tried pushing the pedal to the floor to override the fuel pump relay, but nothing, just turns over. It's getting spark. Once it restarts it will run perfect for a month or week or a few days. Doesn't seem heat related.
Any suggestions.
ECU?
The ECU is the only thing that I haven't replaced. Just wondering, how many of you guys out there have every replaced or heard of replacing an ECU???
Not very many ECM failures. I would keep looking for the problem even though you have replaced the likely suspects. The fact that the MIL comes on when you turn on the ignition means the ECM is getting +12v.
When it happens again, see if you can narrow down the problem to either fuel or spark. Divide and conquer.
Maybe a thread bump will get you some other ideas.
-B-
I concur with finding out which of the three elements of combustion you are missing....we know it's not #1 Mechanical...
so is it #2 Fuel???
or #3 Spark???
You can easily introduce an alternate fuel source (carb cleaner) into a vacuum line to see if it will fire for a moment with this alternate fuel source. And if it fires you know it's a fuel issue. The question is is it a fuel pump? You can pretty easily get to the fuel pump access panel when it will not start and see if the pump is getting it's 12 volts. If it is then maybe it's the pump??? But don't go and replace parts until you've condemned them as failed. I've heard of a problem with the fuel pump bracket not conducting electricity causing a crank-no-start situation when it seems like a pump. But I've yet to see a Toyota with a bad fuel pump. Not to say they never fail but I've yet to see one.
You should be able to get an extra plug wire and keep with you along with a plug....and when the truck cranks-no-start again and you know it's not fuel related, hook up that plug wire and ground it out somewhere that you can see it, then with the DS window down crank it and see if you get a nice blue spark!
There you go...that should at least get you to the bottom of it or very close.
He says he replaced the fuel pump. We have had a couple with a bad connection at the FP and one with a shorted FP wire inside the tank. The short was blowing the EFI fuse so that doesn't sound like his problem. Could be a bad connection at the FP but I would guess he checked that carefully when he replaced the FP. They are kinda spendy.
-B-
-B-
Good catch and good miss by me B....I had a friend (who lives far away from me) with a crank-no-start issue on his '97 and he took it to the dealer who told him it needed a fuel pump. To which I thought humm, never seen a bad pump myself....he put in a the pump himself letting them "diagnose" it and whaddya know....a few days later and again crank-no-start but runs on an alternate fuel supply.
Turned out the fuel pump bracket/sender had an issue, replaced that and problem solved. Only issue, now he's got an extra perfectly good fuel pump and had to fix the problem twice!
We know it's fuel or spark...just need to see which one and why. Where is the Shell Answer Man when you need him??
The Fig
EFI? Limit it to spark or gas problems.
Always three things we need to make a car run:
1. Proper engine function-aka mechanical, cam in timing, cam not broken, compression and the usual stuff, distributor if you have one has not jumped time??? which this again would never cause an intermittent crank-no-start issue.
2. Spark, are the sparking plugs sparking? Are they sparking when they should???
3. Fuel...ahh wonderful atomized fuel...we need some explosive stuff mixed with a little air to make that motor go-go.
Does that make sense or clear anything up?
Or as is often the case just make things more confusing?
Guy's your going to have to be patient with me. This issue only happens every few weeks. It's my wife vehicle, so typically it happens when she comes out of a store or picking up the kids during the day. Then by the time I get out of work and get to her an hour or two later it starts right up, or if she has it towed home the minute it roles off the flat bed it starts right up. so this is going to take me awhile.
Everytime it does it, it sends to error codes. P0100 MAF or VAF A CKT malfunction, and P1300 manufacture specific DTC
If anyone has any idea what these are saying I'd appritiate the input.
Probably should switch vehicles with her until you get it resolved.
-B-
Might be too obvious...
When was the last time the fuel filter was changed?
Air filter & tuna can?
Might want to pull the MAF and test/clean it. It can be tested per the FSM with either a hair dryer or a heat gun if I recall correctly.
Another possibility is grounding. There is a ground to the body in the battery compartment that can cause a similar issue.
Overheating relay maybe?
I'm one of the few who has had to replace the EFI computer. For me it would start then die anywhere from 5 seconds to 2 hours later without warning. It would always start, but there was no way to predict when it would die or to duplicate it by interrupting systems.
Good luck on it. YMMV.
I started having similar issues. I don't know root cause yet. I'm also plagued by an intermittent open in the fuel pump low-voltage circuit (somewhere behind the dash between the relay on DS fenderwell and resistor on PS). Right now my relay is jumpered to always run at 12V. A tweak of the jumper always gets it started, but it's annoying. I'll be tuning in here, and posting anything I find.
Well she died again and I was able to do a little checking. She's getting fuel, but no spark. If I hold the main distributor wire coming from the coil, the second you turn the key there is a big blue spark between the wire and a ground, but then once the engine is turning over no more sparks from the main distributor wire or any spark plug wires.
Would the coil send pulsed sparks to the distibutor or is it a constant flow of juice, then the distributor cap and rotor separartes the flow of electricity to each sparkplug wire????
I have not replaced the entire distributor itself but have just replaced the cap, rotor, all wires and plugs. Maybe its the distributor since the coil and ignitor are new. Or mayb e I should be getting pulsed energy from the coil, which I'm not...
