- Location
- United States
1994 Toyota FZJ80 Land Cruiser
166,000 miles
Factory locking differentials (front,center,and rear)
Old Man Emu J spring lift with Nitro Chargered L shocks
Iron Pig off road sway bar and bump stop extensions and castor correction plates
Man a Fre stainless steel extended brake lines and 50mm front spacer
Landtank DC front drive shaft
4x4 labs Front and Rear steel bumpers (I have slider steps tac welded just not finished yet)
Extended differential breathers
BF Goodrich KO2 with 5000 miles
Eclipse DVD Navigation
Pioneer speakers
Optima red top battery
K&N air filter
New brakes all the way around
New seals and bearing in the front end
Fresh tune up with oem rotor cap wires plugs throttle cable intake tube valve cover gasket fuel filter and egr valve
Beforehead gasket went replaced the radiator thermostat water pump and hose with oem
Valve cover paint with wrinkle paint
I have monstaliner that will go with it to bed line where the fender flares were and the floor in the cab. The ABS and check engine light are on. My mechanic said it need and sensor and o2 sensors.
Unfortunately the head gaskets bad. It happened about a week ago.
Asking $7500 Or best offer. Title in hand
Vin# jt3dj81w5r0090344
166,000 miles
Pioneer speakers
K&N air filter
