94 land cruiser rear door
Louisiana
Can this be fixed or should I replace? It's from a 94 land cruiser.
JunkCrzr89
Competent Ignoramoose
Colorado
Only one way to know for sure: Pull the glass and weatherstripping. FWIW, mine was similar and I repaired it.
Oregon
You have to pull the window and seal. If you can clean it with a wire wheel and some rust converter, and there's still good steel, then you can fix it with some body filler and a repaint. If you've got pinholes or extremely thin sections, you're going to have to have a patch panel welded in or find a hatch in better condition.
If you want to half-ass it, you can push some cord under the seal to keep it out from the body, clean up what you can, rust-convert what you can, and follow with body filler and rattle can paint. If you shoot enough fluid film under the seal afterwards then *maybe* it won't rot out right away.
Here's a video showing the cord/rope technique:
SF Bay Area, CA
Mine was worse and I was able to repair with a lot of grinding, wire wheels and bondo. Pics are somewhere on this site in a similar thread.
