94 Land Cruiser Alternator belt issue.
North Carolina
Hello all, having an issue with my alternator belts on my 80 series. They wear really fast, but I think that is normal. What I am trying to figure out is when installing new belts they do not fit on the the pulleys with just the alternator loosened as designed. In order to put new belts on I have to take the idler pulley off, and take the fan off and tilt that pulley then I can slide the belts on and put everything back on. I am using the factory Toyota belts, I have tried a few aftermarket belts but they wear out faster.
Is this normal?
Been dealing with this for a while, and tired of it now. I would like to be able to just put belts on and adjust the alternator tension.
Just put a new Aisin water pump on, same thing not that it would cause the issue since there are dowels to center it. The alternator has been replaced in the last few years, same issue with the old alternator though.
Anyone seen or heard of this before?
Thanks,
John
flintknapper
Deep East Texas
Is this normal?
Thanks,
John
The matched set belts should last a LONG time.
Its a fairly tight fit and there isn't a lot of adjustment....but you should be able to put them on without removing the idler.
You are routing them correctly right?
Like this:
And NOT like this:
