With the high CO and NOx the engine is probably running lean.
From what I've read, I believe Pin Head is right about CO.With those numbers you do have a mixture problem. It does look like O2s would be a good start. Your 94 has two sensors. They should be side by side right in front of the cats.
Check for any exhaust leaks before the O2s.
Usually if there is an egr problem, the NOx numbers fluctuate during different parts of the test.
If you also had high HC it would look like you'd need cats too.
It is unclear (to me anyway) whether the denso o2 sensor part sold by worldpac (partsgeek is just a worldpac dealer) is one sensor or a kit of two + gaskets and hardware.From what I've read, I believe Pin Head is right about CO.
RE: O2 sensors: crap. I ordered one. I guess I need to order one more for my '94, and I should do better research before ordering parts. D'oh!
Thanks for all the help to all of ih8mud. You guys rock.
CO = incomplete combustion due to insufficient oxygen = rich mixture.
Good info.I factory cats are bolted together but bolts will be rusted. I replaced all my bolts for the cats and heat shield with SS bolts, they come apart easy now.
O2's only last me about 100,000 miles.
When I go for the Colorado Front Range emission dyno test I plan on doing the following:
Air tires to almost max pressure
Remove air filter (my O2 sensors are unplugged do to they wore out again, I assume with the motor is running a bit rich with no O2's so more air flow might help???)
Remove front drive shaft and lock T-case ( should put less stress on engine, I assume that the dyno puts resistance on the drive train???)
Put some sort of insulation around the cats under the heat shield to keep cats hot
Mix some E-85 in the gas tank (see internet tricks for emissions) denatured alcohol is suppose to help too
Fresh oil and oil additive (my motor smokes on startup and uses some oil while driving)
The only thing I need to fix egr is new temp sensor, may try and find a used one.
Not sure if OD and ETC will help or hinder but I would assume that lower rpm"s with = less emissions but thats just a guess. Not sure if the 1FZ motor runs cleaner at high rpm's or at low rpm's.
I'd be pretty angry if they rolled my Cruiser over just to check emissionsWe got rid of emissions testing a few years ago. Thankfully. But when we did have it I think they rolled the vehicle and plugged something into the obd2 port. If there was a cel they wouldn't test. I did t have my 80 but my mom had a 96 back then. It got a high idle test. They didn't put it on rollers
Good link. I saw the spot on the test report for the CEL and I assumed since it says "pass" that the alternative is "failed." Good point on the drive shaft, too. Maybe if I'm feeling cheap and I need to pass I'll try that!Colorado doesnt care if you have the CEL on for its test. http://aircarecolorado.com/fail-and-repair-information/check-engine-light/
For the Colorado emissions test, the tester has to keep your vehicle speed up to certain speeds. I would assume there is some resistance applied to the rollers to see how the motor works under a load.
The last time I tested the tester had a hard time keeping up to the speed needed to pass the test. I later found that I forgot to hook up my transmission cable to the throttle body which downshifting a problem thus making it hard for the tester to increase speeds to match what the dyno wanted the vehicle speed to be. The 80 would downshift too late thus the motor was lugging in a higher gear all the time. Not sure if a lugging motor would be better or worse for emissions testing.
As for removing the front drive shaft, if there is resistance applied to the dyno rollers, then there would be about half as much resistance to the motor if you only had resistance to the rear wheels. IF there is no resistance applied to the dyno rollers, then I would assume removing the front drive shaft would be a waist of time.
OBD2 doesn't apply in this case since '94 Cruisers are OBD1, and I don't think they plug in the computer to OBD1 systems during testing here. Can anyone verify that?
