94 cranks, wont start
Discussion in '80-Series Tech' started by Toyminater, Aug 19, 2006.
  1. Toyminater
    Toyminater
    70
    Jul 20, 2006
    Hey guys where would I begin to look on my 94- it cranks nicely no start, no spark either. I dont want to throw money at it to repair I do have a spare coil and a spare computer but didnt want to try anything until I had a direction to begin to look in. FWIW it has 259000 miles on it.
    THX,
    Cruiser Dan you and I will get real close here in the next few months as I revive this behemoth to working like new
  2. Beowulf
    Beowulf
    12,529
    54
    Mar 27, 2003
    Somewhere in the foothills...
    If you're a 5 banana kinda guy then anything I would suggest would be something you have already tried... probably like the igniter.
    -B-
  3. TX_TLC
    TX_TLC
    1,475
    8
    Apr 29, 2003
    Texas
    Is the battery cranking strong? I thought my old one was fine until I got the new one. It is amazing how over time we forget how fast a new battery turns. Just my $.02
  4. loquito
    loquito
    838
    4
    Aug 6, 2004
    you might try this,
    https://forum.ih8mud.com/showthread.php?t=81604
    Mine would crank over and not start.
    My problem is in the wiring harness that goes under the intake.
    wiggling it around solved my problem even if only temperarily.
    Could be of some help.
  5. Toyminater
    Toyminater
    70
    Jul 20, 2006
    Okay so i tried a new coil.... Nothing- so if i change the computer will i risk damaging the new one?! i will try to see if the wire harness can be moved around and change anything (even though this seems spark related for now) any other advice? the dealer who i bought it from (in chicago off ebay for 1600!) may have pulled something out so it wouldnt run (alot of stop leak in the radiater and no water) and tried to pass it off as not starting maybe, all in all i got a good deal it has the factory lockers and is all highway miles as well as super clean ....... yes i know it doesnt run but i have another drivetrain for it.
    So where do i look now?
  6. bull
    bull
    3,204
    Media:
    11
    Albums:
    3
    6
    Feb 7, 2002
    Pendleton Oregon
    Check your EFi fuse. Located in the black box driverside fender.
  7. Toyminater
    Toyminater
    70
    Jul 20, 2006
    checked all fuses and swapped them too
  8. bull
    bull
    3,204
    Media:
    11
    Albums:
    3
    6
    Feb 7, 2002
    Pendleton Oregon
    Do you have a wire diagram and a voltmeter? Need to figure out where you have power and where you do not.
    Have you pulled a plug to see if its getting power?
    My $$ is on a burnt or disconnected....or even grounded wire someplace
  9. bull
    bull
    3,204
    Media:
    11
    Albums:
    3
    6
    Feb 7, 2002
    Pendleton Oregon
  10. Toyminater
    Toyminater
    70
    Jul 20, 2006
    i am located in St.louis.......... this reader says it is good for 96 and up-- mine is a 94. but thanks for the reply i will start tracing wires tonight
  11. landtank
    landtank SILVER Star
    19,063
    1,246
    Mar 27, 2003
    Groveland MA
    fuel pump relat maybe. Put your foot to the floor and then try cranking it. On the 96, the relay is mounted inside the DS fender just in front of the firewall, a tough one to find.
  12. Toyminater
    Toyminater
    70
    Jul 20, 2006
  13. Darwood
    Darwood
    1,957
    7
    Oct 8, 2003
    Z.O.W.I.E. Headquarters
    Do you have the wiring manual. I would think that would be invaluable for this. I would start checking wires from the distributor back looking for the where the juice ends, but you probabaly have already started that.
  14. SUMOTOY
    SUMOTOY
    1,836
    4
    Jun 1, 2005
    Chicago
    Did you run the diagnostic codes?
    Ignition to on position
    Jump TE1 and E1 of the data link connector (under hood with black plastic cover - connector is labelled with locations)
    Get blink code
    First digit/s, then 1.5 seconds, second digit/s, then 4.5 seconds, next code...
    This should get you closer to the problem. I ran into this on a 93 and it ended up being the ignition switch.
    Scott Justusson
