'94 80 Knocking Sound
mankato, mn
Hey guys,
im new to posting nut ive been lurking for a while. i need some help. i have a '94 80, 160k on it. i haven't done much to it except some 33" xterrains and switched it over to AmsOil synthetic. This morning i went out to start it up to warm it for a trip to Minneapolis and when i returned to the garage to leave i heard a loud knocking noise coming from the front side of the engine. it wasn't there when i parked it from the night before and i didn't notice it when i started it to warm up. needless to say, i drove something else on the short trip. when i got home tonight i went back out there to check things out a little more in depth. i pulled the cooling fan to see if it could have possibly been the fan clutch. not it. then i pulled the water pump pulley and secured the belts back, started the engine and the noise was still there. its not as noticeable when its cold but when the idle comes down from warming up it is definately loud. it seemed to be the loudest between the crank pulley and the head and changes with rpm. i took the wifes stethascope (shes a nurse) out the to listen a bit closer and it stilled seemed to be the loudest at the front of the engine, between the crank and the head. i read here https://forum.ih8mud.com/showthread.php?t=50531&highlight=timing (post 16) that the early "z" s had a problem with the chain tensioner up there. could that be what this is? i believe that's where the timing chain is but i don't have the FSM to confirm it. i am going to try to get that manual tomorrow. any help from you guys would be appreciated. thanks in advance.
mike
mankato, mn
Mike,
That describes the location of the timing chain. It could be the tensioner. It could also be the chain guide (slipper.)
There are reports the early engines (93-94) had chain guides breaking and the new part is improved. Replacement is a big job. Refer to C-Dan's oil galley plug failure for pics and a description of the job to remove the timing chain cover.
-B-
Sorry to hear your troubles and welcome to the board -
I can only add that you should be warned that it can take a couple of weeks to get the FSM from the dealer. Don't bother with the other Hayes and such that are "off the rack".
Hey B, Riley,
thanks for the help. i figured that was going to be the case on the manual. i just rebuilt my '95 runner because the head gaskets went on it. so i'm not afraid of the work but i just dont want to tear into something without having a good idea of what i am looking for. these engines are new to me and as sad as it may be this is my "nice" truck:) so id rather have it done right so i can keep it on the road/trail for another 100k. do you think its ok to drive or should i hang the keys up till the manual gets here? thanks again.
mike
I guess it would depend on how bad you think the chain is slapping the cover. Whether to drive it or not needs to be your call but I think I wouldn't hang up the keys if I thought it was just a weak tensioner. I drove a 911 with a bad chain tensioner for several months before replacing it. I also drove it "lightly" (for me) until I got a chance to tear into it and fix it.
If I thought the slipper was broken and the chain was catching on the busted bits then I would park it. Does that help?
-B-
thanks for the help guys. the manual is on its way from toyota. thanks for the link to the downloadable version vb. i had it on order before your post, but it will make a great reference for now. i think that i will let it sit for a while because the noise is pretty loud and kind of disturbing. i have other vehicles that i can sub in for the time being. tomorrow night i will pull the valve cover and take a closer look. thanks again for all your help gentlemen. i will keep everyone posted on my progress.
mike
