93 LC; drive plates and ECU
Discussion in '80-Series Tech' started by cstamm81, Feb 26, 2007.
  1. cstamm81
    cstamm81
    601
    4
    Nov 28, 2006
    Leesport, PA
    So I am considering buying a certain built 93 LC. In my studies, it seems the 93's have thinner drive plates and peksy ECU's. How big of a problem are these two things. Looks like the ECU's cost about 1200. Do the thin drive plates equal a weak link?
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Moderator
    21,968
    5,722
    Mar 27, 2003
    Land Cruiser Heritage Museum broom closet
    Drive flanges are not really much of an issue. Only April 93 and older vehicles have the possibly problematical ECM.
  3. cstamm81
    cstamm81
    601
    4
    Nov 28, 2006
    Leesport, PA
    Thanks cruiserdan, I will check the mfg date.
  4. Bearcat80
    Bearcat80
    581
    4
    Mar 23, 2005
    Beaverton, OR
    As far as I know, the drive flanges are just different, not necessarily better. I've not seen anyone post a problem with them. The ECU can be replaced with a used one with the right part # for appx $200.00, and you only need to do this if you see the code. The same code can be caused by a slightly too tight accelerator cable.(This I learned the hard way) On the plus side, you get a tranny made for buses, and your code reader comes from your stash of office supplies. I would be much more concerned with general vehicle condition and past maintenance than what year it is.
  5. cstamm81
    cstamm81
    601
    4
    Nov 28, 2006
    Leesport, PA
    crap, looks like mfg date is 1/93. bearcat, where can I get used ECU's for $200?
  6. cruiserdan
    21,968
    5,722
    Mar 27, 2003
    That is an avearge junk yard price. You would search the import yards for a 5-93 through 12-94 donor.
    There is also the possibility that the computer has already been changed. If so it will have an 89661-60221 installed.
    The computer is not doomed to fail for that matter. It's a gamble.
  7. Beowulf
    Beowulf
    12,529
    54
    Mar 27, 2003
    Somewhere in the foothills...
    And if/when they fail, it is not a disabling condition. The truck will still work and run OK. In fact, most of those that have failed have only had the MIL codes as the symptoms.
    -B-
