asutherland
VA7 HDT
When I bought my truck, the cruise control worked. After a few years it now flashes CRUISE on the dash 5 times and then doesn't work.
It passed the Type A diagnostics:
-SET/COAST circuit is normal.
-RES/ACC circuit is normal.
-Control switches:
• Stop light switch
• Parking brake switch
• Neutral start switch
-Drive at approx. 40 km/h (25 mph) or below. - CRUISE on solid
-Drive at approx. 40 km/h (25 mph) or over - CRUISE flashing rapidly
I then did the Type B diagnostics, via the jumper on the OBD1 check connector. It spat back a single code, Indication Code 12 - Open circuit in safety magnetic clutch. I'm assuming this means the actuator is toast. There are a few more steps with the multimeter:
INSPECT ACTUATOR
(Safety Magnet Clutch)
(a) Check that the arm moves smoothly by hand.
(b) Connect the positive (+) lead from the battery to terminal
5 and the negative ( —) lead to terminal 4.
(Safety magnet clutch turned ON)
(c) Check that the arm does not move by hand.
If operation is not as specified, replace the motor.
Assuming these tests will fail, I'm trying to source a new actuator. The actuator part number changes from 1990-1992 vs. 1993-1997. In USA land, 1993-1997 part number is
88002-60030
Example: CRUISE SPEED REGULATOR 1996 Land Cruiser P/n: 88002-60030 R258013
I know the JDM part number may be different, but on physical inspection it looks the same (especially if you buy just the motor as in the ebay link above). Unfortunately the label with the part number on my truck has faded to the point I can't make out the part number. @Akella do you know? The cruise control actuator is on the same physical side on the US model 80.
Andrew
-Control switches:
• Stop light switch
INSPECT ACTUATOR
88002-60030
Andrew
