I have been battling an overheating issue on my rig for a LONG time, since I bought it. So far I have done the following:
I am STILL overheating. I get heat soak headed up hills that doesn't really ever fully recover. Its gotten remarkably worse in the last 30 days. It will quickly climb to outrageously hot (assuming my dash gauge is accurate) and then slide back down to the middle of the gauge. The entire process takes maybe 60 secs.
I had an epiphinal moment yesterday that it happens much more frequently/worse when the heater is ON. In fact, since the last round of work (~2mos ago) I cant think of a time when it happened when the heater was NOT on.
The only thing I can think of would be a partially obstructed heater core? Is there anything else that could be causing this? Can I flush the core while en situ? I just recharged my AC system and do not want to pay to do that again, nor do I want to deconstruct me entire dash.
Open to thoughts from folks.....
- Raventai gauge mod (~3yo)
- replace the radiator (~3 yo) - found clogs in it
- new OEM thermostat, oriented correctly (~3 yo)
- new blue hub fan clutch, modded with 30k CST (~6mos ago) - it was old and manky
- re-did the PHH bypass (~2mos ago) - found a leak
- replaced the heater control valve (~2mos ago) - it was leaking
- checked for leaking exhaust (that ones for you @NLXTCY)
- checked for exhaust gases in the coolant (~2wks ago) - negative
- pulled my plugs - they look carbon fouled consistent with the miles on them
