93 Exhaust Gaskets and Fasteners P/Ns (1 Viewer)
PNWTreeOctopus
Saint Paul, MN
I’ve been trying to do my homework here, searching through the threads about exhaust builds, but I need some simple confirmation about Part numbers on my 93 LC. I need to replace most of the gaskets and fastners and when I started entering numbers at McGeorge Toyota, some of the part numbers came up as a non match on my 1993. This always throws me through a loop. Here’s my list og gaskets and fasteners from from the headers to down pipe downstream. I’m feeling fairly confident about most of the gaskets except the EGR pipes...but before I toss $$ towards parts I just need a little help making sure they fit. Thank you in advance.
Gaskets (In Downstream Order):
EGR Gasket: 25628-66010 x3
Header to Down pipe: 90080-43036 x2
Cat gaskets: Front: 90917-06043 x2
Rear: 90917-06076 x 2
Y-Pipe to Muffler: 90917-06076 x1
Muffler to Tailpipe: 9091706072 x1
Fasteners:
Bolt: 91511-61035 x10
Nut: 94180-41000 x10
Stud: 90080-12007 x4
Nut: 90080-17187 x4
Go to partsoq.com put in your vin and it will show all the part numbers. Then either order from there or USA.
And this is what I did. I’ll comfirm fit for posterity if they are accurate!
Fasteners:
Nut: 90080-17187 x4
I was thinking there's only two EGR gaskets? I replaced the 25627-66010 only when I did my intake cleaning and HUDDEXPO EGR delete. If you're including the two PAIR gaskets, just delete that sucker!
Right! It’s tempting to delete, but I’m looking to solve a low idle problem, found lots of leaks and just need the cruiser back up running well for the remainder of the ski season....the Subaru is faster, but the cruiser is a portable chalet...
I know lots delete EGR and PAIR but I haven’t done my homework on it yet, so I’m not quite ready to head down that path!!
