You got a great deal but if you continue pulling parts off the engine like you have been without reading the fsm you are going to cost yourself thousands.
Another note about these cars/engines: they reject non Toyota parts faster than you can unpack them from the amazon prime box. Buy Toyota parts ONLY
Well im back to square one. I took the battery out to put the battery box back in. Re connected the battery and cranked it over to test drive and it wouldnt even idle. IT STARTS BUT immediately dies. Doesnt even try to run like it was doing. I have spent the last 4 days going through the FSM and trouble shooting section. I adjusted the TPS as per the FSM. I checked the IAC and VAFM per FSM. They all check out good. I just dont understand. Only thing I can think of is the Fram fuel filter I put on is no good or somehow replacing the belts messed something up. Just dont see how either of those could be the issue. Im out of ideas and completely frustrated. I jumped TE1 and E1 on OBD1 to see if I could get any codes. Nothing. Turned key and CEL came on but did not flash.
