A few weeks ago I purchased my first Land Cruiser, a 93 with 276 thousand miles. It has a lot of miles, the interior is trashed and it has an unknown service history, but I adopted it anyway. It is not showing any signs of engine issues, clean coolant, clean oil, no condensation under the cap, head gasket not weeping externally, engine actually seems solid. I have not performed a compression test, can't find my old tester, haven't bought a new one. I started doing some basic engine maintenance and clean up, and have a bad case of "while I'm in there" now. Plugs, wires, cap, rotor, filters became a re-seal when I realized the head gasket was about the only seal that wasn't leaking. While looking at the oily undercarriage I realized that included the oil pans (who knew these had 2 ?) and probably a rear main. Once I decided to pull the intake manifolds to replace vacuum lines and service fuel injectors, I decided to go ahead and do the head gasket while I was right there. Figured if I was going to lift the engine to do the pans, it would be a good idea to do the engine mounts while I had it apart, and hey, if I'm going to have the pans and the head off, it would be a good time to pull the timing cover (crank pulley / balancer is going to be off anyway to get to the front seal and oil pump cover seal) to check on those guides that I hear were updated after my very early engine... Now, having said all that. If I'm going to have it this far apart, does it make sense to just go ahead and pull it to do rings and bearings as preventive maintenance ? I hear all the stories of these still showing factory cross hatching in the bores, but read a few stories of spun bearings near my mileage. Ideally the bores and crank would still be in spec and I could have it honed and the crank polished and replace with new "standard" parts. Any gotcha's, or something my ignorance of this motor might be missing that would make this an impractical or bad idea ? If I'm this close, then need work in the block in 20 thousand miles, I will wish I had done it while I was in there. I do plan on making this truck a long term project and expect it to be with me a long time unless something goes horribly wrong.
Thanks for reading all that ! Guess I should have done an intro thread and just asked the question in this one, but...
Jason
Jason
