92 Nissan maxima Starter replacement?
Status
Not open for further replies.
Cuba, MO
Hey guys....I figure the all knowing MUD brain will know the answer to this problem.
My neighbor owns a 1992 Nissan Maxima and it will not start. There is power going to the starter according to my charge light, and I can physically feel the starter clicking. Its clicks once per key turn but will not turn the motor.
I pecked around on the starter as the nissan dealer's mechanic told me I should and still didn't do anything.
My neighbor was wondering how hard it is to replace the starter motor in a V6 Nissan.
This motor is the type that is turned sideways in the car and the starter is very accessible at first glance.
lunyou
tcb
Swinging from a vine.
Tap on the starter with the heavy end of a screwdriver and see if it will catch. I had a blazer that had a starter that would do that once upon a time, a good wack and it would start working again. Worth a try.
I have no idea what it would take to change it.
Cuba, MO
well i pecked around on it with a heqavy socket wrench and nothing caught....of course I wasn't tapping hard enough due to my lack of knowledge how hard was too hard.
lunyou
tcb
lunyou
You can't break it any more than it's broke, can you? Knock the piss out of it.
it not hard to change that starter,it probably just needs new brass contact
I've had a '90 Maxima SE (5spd) and had intemitten(sp) starting problems.
I would turn the ignition and it would just click, but not turn over. It was usually solved by turning the key on and off, on and off, several times until it started.
GOOD LUCK!
Cruiserdrew
On the way there
Sacramento, CA
My 18 yo :princess: has a 95, so the starter is likely the same. If the starter says Mitsubishi, there is a bushing inside that wears out. At first it makes a bad noise and will start. That lasts about a year. Then it makes a very bad noise and won't start. You can't just replace the contacts like a Denso starter. You need a whole new starter. I believe you want the variant made by Hitachi. It does not have the bushing problem.
Since replacement a year ago, it's been 100%.
I have found the Nissan difficult to work on myself. It isn't logical like a Toyota. In my life, I have owned 9 Toyotas, 1 Chevy, 1 Nissan, 3 VWs, 1 Subaru, 1 Acura, and 1 Dodge. The only ones I enjoyed working on were the Toyotas and the VWs. Toyotas are meant to be serviced, Nissans are meant to be serviced at the dealer. It's a surprisingly big difference.
Status
