92 Headliner bracing diagram
LS1FJ40
Cedar Rapids, IA
Anybody have a drawing of the bracing or what is behind (between the liner and roof) the headliner? I have an idea for an overhead storage unit but not sure what is behind it that I could attach to. I've check the FSM and Haynes manuals but can't find anything. Searched MUD and can't find anything. My 92 obviously has the cloth headliner. Thanks.
I can snap some pics of my 93 with cloth headliner out for sunroof removal and hole weld up early next week when I get back to work.
Ok. Thanks. That would be great. I'm curious what the bars or battens or whatever are at each seam particularly. I want to bolt/screw in an overhead cage/shelf that would also double as a retainer for the sun visors so they don't hang down. I don't have a moonroof so it might be a little different than yours but hopefully give me an idea.
Bump for anyone else that might already know...
Bump for info. I'm interested too
Another bump because I'm dying to make this! Contemplating drilling through the roof and mounting a light bar and using the same bolts to hold this instead. However, I don't have a light bar yet and want to do this. :)
I wanna see how the rear washer hose is ran in the headliner. Mine is clogged and I can't get fluid to the back. Wanna see how hard it is to rerun one.
For the rear washer...
For the headliner...
AWESOME!! Thanks Golgo13!!
This should be interesting... :)
Those are from the parts catalog, but they're also available on Toyotapartsoverstock.com.
I have no affiliation with that site, I just find it really easy to get part numbers and diagrams from them.
Then I call my local dealer or one of the 'Mud vendors.
I'm curious to find out how strong the cross braces are. I'm not going to hang a ton of weight off them but about 5 lbs.
Worse case I just run bolts through the roof when I get an LED light bar...
I'm wondering if anyone has the dimensions from the front (windshield opening) of the roof to the first main roof crossmember (63141G in the above schematic)? I'm guessing you'd have to have a roof with the headliner removed to be able to see this.
Is that diagram from an FJ or FZJ?
Those were from the 1992 FJ80
What is your timeline like? I might be able to help
PM me and let me know.
