'92 HDJ81 (1HD-T) BEB mechanic in Lower Mainland??
On a side note, I'm using 10W-30 oil right now (as some of you probably already know) and my oil pressure is usually at the "1/3rd" mark when I've been driving around for ~10 minutes. Does anyone know if this is enough pressure for this engine or should I just switch over to 15W-40 asap??
Thanks,
Rob
typical of this engine's oil gauge. Mine hardly ever goes past the first third, and if you check with others, it's pretty much the same for most of us. It's a known weakness. Best way to find out is to connect a standard mechanical gauge using a T off the sending unit tap under the oil filter. It's a metric fitting, BTW. 10mm IIRC. Haven't done it yet on mine. If the oil gauge is flaky you probably won't notice much of a difference when changing to 15W40, but do it anyway, especially if it's hot and you rrun the engine hard (=sustained high speed driving).
