So, plan is...
I have a diesel (6BT) in my 80, rev limit is 3000RPM, so half the tach is not used.
The white gauge faces were for the 93+ 80 series, and do not line up with the 91-92 speeds, and revs, also I think one of the side gauges was different.
I knew there may be issues before I ordered, but Im going to send the company "whitegauges.net" my gauge faces so they can add them in to they're system.
I want them to do a custom tach, where it ends at 3K, and redlines for 2500-3000. Then hide the rest of the lines. With the rest of the real estate on this gauge, I want to put boost and pyro there.
I'm thinking a small needle gauge could fit maybe. But looking at how the light goes through the material, I think I will use digital gauges, which read through and are maybe hidden.
The black face i put a scratch in to see the light come through, the scratch will be hidden except for back lighting, and digital numbers look like they will shine through both the face and white plastic cover.
As an FYI, I had the truck broken into and A pillar gauges torn out about 7 years ago. Adding this into the stock cluster will keep that hidden and not attractive to theft, plus it will not be obtuse or take up more space. This pyro from china and a similar boost gauge I think may fit in behind the cluster. I have the boost on order
Smarter Shopping, Better Living! Aliexpress.com
Id like to add both pyro and boost behind the face, whenever I get the boost gauge Ill see how it fits. I might see about custom ordering the gauge faces to say "boost" or "egt" beside or above the numbers when I get it laid out.
Also, I think there may be a chance that toyota gauges (maybe from a different and narrower cluster) could be fit into the 80 series gauges, and actually add in something like oil temp, or trans oil temp onto the factory gauge face.
