Miscellaneous stuff I pulled off my 80.
Front coils 21" 9.25 wrap, blue pink white, coils - 40$
Rear coils double green - orange, double white - blue, 40$ -SOLD
Upper link, 30$
Lower links, 30$ each
Rear panhard, 40$
Front panhard, 50$
swaybar 50$
t-case 150$
front drive shaft 50$
rear drive shaft 50$
gas tank -- stripped 50$ I can put it on a pallet via fastenal
transfer case shifter and knob 30$
3 hub caps for 15" alloy wheels 15 each
3FE parts
Rubber distributor cover - sold
OEM Toyota Japan Starter -- 40$ - SPF
oil pan - 50$
very new aftermarket alt - 20$
exhaust manifolds 30$
oil fill cap 5$
push rods 30$
rocker assembly 60$
valve cover 40$
rocker box cover 20$
oil pump 15$
transmission crossmember 50$
the splash guard skid plate that mounts under the bumper 20$
Just added:
Aluminum bumper cover deal - 30$
bumper corner piece deals -15$ each
heat shield deal that hangs under the rocker - 15$
oil fill cap 5$
random bracket that bolts to the side of the frame? - 10$
fuel tank strap - 15$
fuel tank hanger 10$
OEM distributor, I dropped it so the cap broke and I think it broke off a chunk off the casting I can't remember, it's for parts - 50$
coil igniter - $20
heater coolant hard lines -20$
power steering return side hard line - 20$
brake LSPV bracket rod whatever, not sure on condition of LSPV but brakes worked find when I yanked it, but it has been sitting outside -- with lines attached... May only be good for parts??? -20$
brake union I cut off... 5$ may have another one somewhere...
2 more frame brackets deals - 10$ each
all parts $ + shipping
Upper link, 30$
Rear panhard, 40$
Front panhard, 50$
swaybar 50$
t-case 150$
3FE parts
oil pan - 50$
oil fill cap 5$
push rods 30$
rocker assembly 60$
valve cover 40$
oil pump 15$
Just added:
oil fill cap 5$
coil igniter - $20
