My 92 the other day, started, but then died after about 5 sec....WTF. I went through all the wiring, vacum hoses, and even checked codes, but no codes. I checked to see if the fuel pump was gone, I did have power to it. Then I pulled the fuel line of the pump and did have fuel pumping. I had the girl towed to my mech. That was sad to see her on top a flat bed.
I just read a thread, that was posted and you guys talked about the EFI relay. Could this be a possible problem? My mech has had it for a day and half now with now calls. Maybe I will call and let him now about the relay. Any other possible ideas on what is going on? More about what had happen, The day before when pulling up to the light, it stubbled then died, she started right back up. I got to work, she sat for 24 hrs, got off shift, went to start, she started for about 5 secs, then died, tried again same but shorter time. Hope this helps for you tech heads, give any input,PLEASE.
WoodyFJ
