Thanks Gary! Yes I do realise that, I want achieve an increase in power though it seems an intercooler may introduce exta turbo lag...
I sussed out the running hot problem, the coolant was old & dirty & so contributed to corrosion of the waterneck/cap area. I had to clean up & lap in the seat/sealing area inside the neck as it was obvious the cap was not sealing/maintaining any pressure, the thermostat was fairly new looking and tested fine, with the system flushed & a 50/50 mix of antifreeze/inhibitor in she ran normal temp at 100 kph.
The radiater & the head are near new, 3 yrs ago according to receipts I have.
Thanks for the waste gate tip, I'll give it a try.
I think some Toyota light trucks had a 2.4 intercooled turbo, maybe I can find one here worth fitting?
Mine has done 209K's and the only thing wrong with it now is the clear coat on the bonnet & roof has eroded badly, It is common on this model I hear, I'll repaint them later. Not a bad buy for $4k NZ eh!
It is replacing my old 69 SWB Landrover with a Falcon 250 in it, mainly used for deer/pheasant hunting & firewood hauling.
Brian Levin NZ
