91 T-Case. Why do I have to have full time hubs?
Twin Falls Idaho
Ok I was told if I ran lockouts I would burn up my transfer case. THis makes no sense. If i use lockouts I would still be turning the front driveshafts just not the hubs. If the t case is lubed by the front shaft turning I wouldn't change that. I found some factory lockouts off a 85 pickup I was gonna slap on but I figured I'd check before I did it. The only reason is I figured it would be less pull on the motor not turning the front tires and less wear on the front axle. This by the way has to be the most gutless rig I've ever owned. I sure love to drive it. What is the lifespan on a properly maintained 3fe engine?
Not so much a fuel issue as a wear issue. I'll keep the drive flanges on board incase I blow a hub.
I think you just need to lock the center diff to make this work if not all power will go to the "free wheeling" front axles. I haven't heard of many issues with wear in relation to the front axle as long as maintenance is done.
Someone who knows the 91-2 X-fer case should speak up. From what I understand these 2 years of T case did NOT have the viscous coupler, so Im not sure how this impacts burning up the case like what a viscous coupled case has. I understand that the case is the same from 91-7, except the 91-2 did NOT have the viscous coupler on it. Either way, if you have the center diff lock switch on power will be delivered evenly to front and rear driveshafts, but with the hubs unlocked you'd only be in RWD.
HTH
Cheers
You CAN put manual hubs in.
You CAN reduce wear on your front end.
You WILL have to lock the CDL in order to run with unlocked fronts.
No, you will not get better gas mileage (meaning it will be better, but statistically insignificant)
No, the 91-92 80s did NOT have a viscous coupler.
You can also order a part time kit, swap out the T-case gearing and press on a new gear and get the non-fulltime 4x4 setup. It will also eliminate your clunk (if it isn't your driveshaft).
Please return to your normally scheduled program.
I'm not buying the reduced wear unless you pull the front driveshaft. I did this with my 91. It was a PITA. I also found I did not like the driving characteristics of the RWD only 80. If you lock the center without removing the driveshaft you are still turning the front driveshaft and third and axles. You just aren't putting power to the front wheels. I found that by removing the front driveshaft it felt like I had a little more power but mileage did not improve. However, I was driving a 91 with 35s, a 4" lift, and a bunch of steel protrusions. A guy I know has a completely stock 91 and he removed the front driveshaft after installing hubs and he has bumped his mpgs 2 mpg. At current gas prices this could be significant if you drive a lot. The inconvience is major if you get off the road frequently.
Dan,
I agree with all your points but could you please elaborate just a tad on the reduced front end wear.
-B-
Gotta be less stress on the birfs as they are not turning anything but themselves. Same with pinion bearings and axle bearings. Instead of turning a 50 pound tire wheel combo on both sides that will never be perfectly balanced you are turning a small rotating mass axle shaft. I found two sets of Aisins at a yard for 80 bucks a pair. From what I've seen thats pretty cheap. Two sets for 160 bucks beats 400 for one brand new set.
