91 SF Rear Axle Bearing Groove
Content may include affiliate links. Please see terms for details.
North America
I am replacing the driver's side rear axle outer oil seal today - looking at the axle shaft itself where the bearings ride, does this seem normal to have such a deep groove or do I have a problem I am unaware of? Bearing itself seems to be visually in great shape and in working order as I spin it with my fingers...however this truck has well over 300K miles - TIA for any help/ideas!
cruisermatt
Un-manufacturable
Supporting Vendor
Winter Park, Florida
Website
www.facebook.com
replace that shaft and the bearing.
North America
Thanks CruiserMatt - I figured so....any other things I should be concerned about or look at while I'm into it this far?
cruisermatt
Un-manufacturable
Supporting Vendor
Website
www.facebook.com
I would say make sure you flush the gear fluid really well from the third member, also make sure to inspect the other axle shaft.
Olathe, KS, USA
You will discover that the truck will be a LOT quieter to drive when you get it back together.
If you are carrying lots of weight in your LC, you may want to consider swapping the rear SF for a FF.
That is a perfect example of why FF is better than SF..
North America
Sadly I won't notice the sound difference because of the Cummins swap - the biggest weight change is in the front, but in the rear I do have HD springs but only carry about 250lbs of gear in the rear regularly, and that's with the 3rd row of seats out so it shouldn't be over loaded in the rear. Good point though overall about FF vs SF rears. Although the mileage this thing has clocked before any issue is impressive. Passenger side axle is in great shape but I am replacing them both with Chromoly Longs now lol
